It's mostly this:
but since you mentioned this:
the laws of the internet require me to go with that.
You're stupid.
And now that that is out of the way, the long ass post that I had typed up in condensed and simplified form before I "LOLd" the entire thing.
The issue at hand appears to be the lack of a definitive final outcome goal. You say 400hp but then meander on to building up to hold whatever you may want to throw at it later. If you truly want more than 400hp you realistically need to just dispose of the notion of building for 400hp and set a real target. A reliable and affordable 400hp 7M is actually fairly easy and comes in well under $20k. That same build however isn't very reliable north of 500hp.
Having "soft goals", i.e. goals with no hard/set outcome, almost never work and you end up with $20k in a build that doesn't even look like a car, much less is a reliable daily driver. Set a desired outcome, and stick to it.
Fix this before starting any type of swap or build, as they tend to complicate any prior issues.
Nope, opposite actually. It's rather refreshing to see someone look at it from this point of view instead of YOLOing it and whining when pistons develop windows.
Haha, fair enough! I feel pretty stupid, I tried to fix my window switch the way you explained in a different thread, but just ended up making it worse (auto windows and window locks don't work) and I didnt even fix the issue I had previously.
... and I broke one of the tabs, it took almost zero effort, but I got super glue and sort of fixed it.
Regardless, I'm awful with hard goals. My decision making skills are good, but I have troubles sticking to a decision, which makes them bad.
My overall goal and dream was to have a 500hp daily driver, so thats where the 400whp is coming from. But yknow, as we all tend to be, eventually we want more. I know at some point I will want more. I will want a turbo LS in my car, or a 2JZ big turbo. My issue is, I can't tell if it will be years or months before that want comes into play.
My LS engine builder is "saying" that the LS1/6 build he can provide me for $5500 is nearly an identical build that he is throwing in his 600whp Mustang, the only differences being the cam and valvetrain internally. That sounds rather like something I'd be interested in, especially if it's going to be reliable like he says. Buddy has been building V8s and LS engines for over 15 years now, he seems to know whats going on with them. But it all boils down to a sales pitch, so I take it with a grain of salt.
@Wreckless After pricing it out and researching, the 2JZ NA-T build is closer to 12k here in Canada. FFIM, single turbo kit, eagle rods and engine rebuild, JZ bellhousing, motor mounts, flywheel and clutch, as well as an intercooler and all the plumbing. Work a standalone and wiring harness in, tuning, fuel upgrades, etc etc it adds up with shipping and conversion rates. Just finding a complete longblock assembly is difficult, and a bit pricey, but still cheaper than the rest. I'm still looking into it. It seems like the 2JZ is way easier to swap in, but to make my power, its more difficult/more effort.
My 7M just got a composite HG and ARP studs. The block hasn't been opened up, ever, which makes me hesitant to build the engine for higher horsepower without a rebuild or MHG. Technically, it only has 120k km on it, but its 33 year old seals and such. I'm surprised my oil pan hasn't leaked, or anything else for that matter. Most of my accessories appear original, my turbo is obviously stock, anything on the intake side is original, injectors too. I worry that if I push any more power through it, something isn't going to be happy, and then that will break another thing, etc etc.
Once I get my refunds and tax returns, I will be looking at buying an engine and slowly building it on the stand. Definitely not going to be an "all at once" project, or even within one year.
Also looking at trans rebuilds. Not cheap.
Thank you to everyone for posting and helping me out.
