So guys, update time.
Pulled my 7m finally! turns out one of my motor mounts had separated from the rubber and I couldn't get the nut off, so the sledgehammer helped out.
Having some issues taking the r154 off the motor, I have read I need to get the clutch fork out and its a pain so will be doing that later.
I have decided (and already bought) a low mileage (58k) JDM 2JZGE out of an Is300/altezza from a jdm importer.
due to the nature of this engine, I am heavily considering skipping the rebuild process and just going straight for boost - but obviously not high power. I have read/heard that the max the GE VVTI rods can take is 350-400hp? is this wheel rating or crank?
I was thinking about doing a quality NA-T build to aim for 300whp reliably until I am in a better position to afford a full engine build. Without rebuilding the engine, I am saving myself 4-7k of this build that I could put elsewhere such as paint or new tires, etc.
Here is the breakdown.
2JZ-GE VVTI, with an R154 transmission.
JZ Bellhousing
Rear sump pan
Driftmotion NA-T Turbo kit (without turbo)
An appropriate T4 turbo (Still need to do a lot of research on turbos before deciding, suggestions very welcome)
Gasket kit to refresh the engine
Driftmotion mk3 mounts
Walbro 255 or similar
Appropriate clutch kit (I need one for a 7M, right?)
Lightweight flywheel (1jz)
Poly motor and trans mounts
Ebay FFIM and fuel rail with return (
@Wreckless, the one you sent me). Unnecessary but I absolutely hate the GE and 7M style intake when I go to work on the car.
Tweak'd Harness
ECUMaster Classic or AEM Standalone, still undecided.
Appropriate injectors (need suggestions for the new idea for power (300whp daily driver)
3in intercooler pipes and a good front mount intercooler.
3in downpipe and custom exhaust as I sold my old one.
Gauges gauges gauges
A dyno tune
Fluidampr or ATI crank pulley
New timing kit and serpentine belt
Water pump
New starter
Fuel pump 12v mod
New sparkplugs
2jzgte throttle cable
Now for the optional/things that I am considering. Or unnecessary but nice things
Lightweight pulleys
One piece driveshaft
Oil cooler (I'm not sure as to how I would install this, is there a sandwich plate with oil cooler line holes for the GE? Like how the 7M is?
Mishimoto or koyo radiatior
Electric fans? Or stock is300 fan but its ugly. Undecided
New hoses all over
EGR delete (Its a JDM engine so I dont know if it has EGR?)
Engine bay painting and detailing before the engine is put back in. Definitely cleaning it.
Battery relocation to trunk
Driftmotion r154 short shifter
marlin crawler trans rebuild
New sensors
2JZGTE valve covers so I can use the GTE sparkplug cover
Head rebuild ?
Okay now for the question time
With my lower power goal in mind currently, will I still need to switch the head gasket to a GTE one to lower compression or will I be better off sitting with the stock gasket?
Where and how do I hookup a turbo oil feed line on the NA engine? And do I need to worry about water cooling the turbo?
Where and how do I put an oil pressure sender? I can take the one off my 7m and put it on the JZ
i dont know where so that my stock gauge works, will that be viable?
Do I need to worry about anything in my fuse box if I get the tweak'd harness or will it theoretically be wired up properly?
And the ultimate question: Is 300whp safe and viable in a daily driver highway cruiser on stock GE VVTI Internals? If it even lasts me two or three summers I would be more than happy. The original plan is still the plan for the future, however, its simply not realistic given my current situation and I wouldnt mind saving the money now and spending more time/energy/money in a few years when it is realistic to do so.
Oh and I guess one last question, can standalones control the VVTI if its put in the tune? Or will it be obsolete?
Thanks.
