Hey guys, I have to pull my engine, 2jzgte in order to replace a spun main bearing on #3 cylinder. The engine is completely stock with a little over 8,000 original miles on it. I will probably get away with changing the bearings and at most a rering kit. My question is while I have the engine out, what would you guys suggest changing or upgrading while I have it out. I will probably upgrade the head bolts and the head gasket, I do eventually plan on upgrading my turbo's to a bigger single or twins. Not sure about turbo's yet as there are alot of choices. I just don't want to pull the engine and put it back in and find out I should have done something when I had it out, any input would be greatly appreciated.
