R
Roadsense
·Guest
Anything I should get done while my engine block is completely removed from the car? I'm currently full BPU.
Originally posted by Pole Position:
<STRONG>Anything I should get done while my engine block is completely removed from the car? I'm currently full BPU.</STRONG>
Originally posted by V8THIS:
<STRONG>If you're pulling it out and not already planning a full rebuild I would suggest the following. Not cheap when you add it all up, but well worth it if you plan on keeping the car IMO.
Remove the head, have it rebuilt and ported since a lot of people are having problems with valve seals.
While the head is off the block, pull the pistons / rods and (no need to remove the crank, etc) have the block rehoned and put in some new rings. I wouldn't worry about the main bearings, my friend's motor was rebuilt with over 90k on it and the bearings were like new according to the machine shop.
Balance/blue print injectors
replace 3 small coolant hosts at the back/top of engine bay
replace cluch or upgrade torque converter
Send the turbos out to be rebuilt or throw in some very low mileage ones.
Install EGT if you plan on doing a/f tuning.
Replace pressure tank if you're not on TTC
Replace oil pressure sensor with revised unit
give the radiator an acid bath
Timing belt, tensioner, water pump (duh)
-Mike
[/QB]Originally posted by Pole Position:
[qb]Anything I should get done while my engine block is completely removed from the car? I'm currently full BPU.</STRONG>
Originally posted by [3L]:
<STRONG>Hmm do u even own a mkiv?
[/QB]Originally posted by V8THIS:
[qb]If you're pulling it out and not already planning a full rebuild I would suggest the following. Not cheap when you add it all up, but well worth it if you plan on keeping the car IMO.
-Mike
Originally posted by Zerosoul:
<STRONG>damn that sounds expansive..how much to rebuild the head, replace ring and rehone?</STRONG>
