1 - 3 of 3 Posts
the gauge on my fpr wont stay consistent. The adjustment knob on top does not even do anything unless you tighten it way down. Which at the end it will increase pressure alot. Sometimes it idles at 50 psi then when you stop it will idle at 20 psi. You cant ever lower the pressure from what it is at. Any ideas? Bad fpr?
Discussion Starter · #2 ·
Could it be something wrong with the pumps? When i put the twin walbros in, I hooked the vaccum hose that goes down under the tank to the nipple on top of the hanger. Is this right? Or should I run a hose from the Hanger to the other nipple on top of the tank?
1 - 3 of 3 Posts
