1 - 10 of 10 Posts
Newbie
I have a question about the M/T ET Streets drag slicks. Are they DOT approved because people actually drive on public roads with them on? Or were they made DOT by M/T so racers can use them in "streetire" class races?
I live about 2 hours from the nearest track, 100 miles of backroads averaging 45mph. I plan on driving there with the slicks on, I don't have room to take them with me and put them on at the track. Has anyone driven a good distance with these slicks on? What psi should I set the tires to for the roadtrip there? Thanks.
Newbie
Thanks for replying. I know that they are DOT approved, I was just wondering if I can actually drive on public roads with them on? I have to drive 100 miles to the nearest track.
T6Rocket said:
There is no max of 20 psi. Take turns at 100 MPH? You cant even take an off-ramp at 35 if you have them on 20 psi! It feels like the back end is going to come around!
Al
It says max load 1476lbs at 20psi cold....what exactly does that mean then? Is it safe to go above that?
1 - 10 of 10 Posts
