I have a question for all of you guys running ET streets (not the drag radial) with the Rx7 wheels. Are all of you guys using skinnies? What tire pressures are you guys running in the front tires if you arent using skinnies? How low do you guys go with tire pressure with the et streets on the rx7wheels? Is the sway really that bad up top? I have a TRD LSD, would that make things better? Problem is im about to buy some rx7 wheels wiht ET streets, but i dont have front runners.
