I found the eacv wire just fine. its right next to the wastegate.
just like the article said it was.
wire color = green/yellow.
but I cannot find the wire that is suppossed to control the iacv.
the article says that it is directly over turbo # 2.
and that the wire color = green/blue
well I found 2 different connectors on top.
the one circled in yellow is a green/black wire
and the one circled in red is green/red wire
im 90% sure its the one circled in yellow but i want to make sure before i cut it.
After I have installed all the new seals, BCsprings, retainers, locks and buckets,
with T-belt off, put crank at -10 btdc so all pistons are slightly down, install new BC 272 cams, install cam gears, torque cams as per manual. Then turn CAMS clockwise to tdc notches, and than turn CRANK to tdc...
Recently acquired a rhd supra and slowly starting the process of swapping things over. Got myself some glass headlights and wanted to swap bulbs while I’m at it. Been told jdm lights differ from usdm. Hard finding more info on this. Thoughts? Trying to find a quality hid system, seems LED isn’t...
I came across asking myself today, do you need a igniter when you go to a aftermarket ECU and Harness? I noticed my friend is running a MOTEC and does not have one for his car.
Hey guys,
Just installed a pair of S2 taillights on my 93 Supra RZ. I would like to convert to LED. I would like to purchase from here as the prices seem very good.
https://www.superbrightleds.com
According to my search in the Forums, looks like I need 2 x 7440 and 2 x 7443 bulbs Just not...
