1 - 11 of 11 Posts
Dsm killer
what is the ettc mod, 12v fuel pump mod and what is a el2 gauge controller? Sorry for the stupid questions, im brand new to this.
monty
electronic true twin conversion (ettc)
lets you have a switdh to disable the sequential turbo sytem and it lets both turbos spool at the same time.
12v mod is just putting the fuel pump in a constant high voltage state to keep the car from running lean when it switches from low to high voltage.
i dont know what the el2 is though??
Also, iof your new and trying to learn. either go to the FAQ forum, or go to MKIV.com to learn just about anything you have a question for.
Dsm killer
is it hard to do the ettc mod? And can i learn about it at mkiv.com?
Supra TT Senior
monty, i believe the el2 is the new apexi gauge system. It has gauges that can be monitored all thru a main box.
Yeah the EL2 is the new line (not so new anymore) of gauges from Apexi. You can control them from a central box. I have the gauges and they are like any others.
Dan 16s said:
ok is the fuel pump good? what is the gain in HP?
You wont really gain any HP from it. You might gain some midrange HP when , but i wouldnt count on it. Its jsut a safty precaution from running lean.
Dsm killer
Discussion Starter · #11 ·
thanks for all the info guys. VERY helpful
1 - 11 of 11 Posts
