greasemonkey
is there a number i can call to contact hks to get my evc 3 repaired? i emailed them and never got a response. it reads vac and boost fine but for some reason it wont control boost properly. i dont know whats wrong with it. itll work fine to ~10psi. if i try for anything higher it acts as if the wastegate hose is disconected intirely. i have pulled the stepping motor apart and the seals and everything are fine. i just want it fixed.
william
try switching the vac lines around. switch the lines from the compressor housing with the one to the waste gate. i had mine switched up and it would go over the boost that i set it at. so tear it down, and rconnect the vac lines over again and make supre they're going to the proper spot on the stepping motor. good luck, hope this helps
greasemonkey
thats not it. it worked fine for over 2 years with no change on the lines plus i already double checked that. there is something just wrong with the unit. i currently have a mbc hooked up for the time being.
Just some guy
(310) 491 3300
Just give them a ring and ask for the tech dept. Let me know what you find out. I have an evc4 that I would like to get working again (it also doesn't control boost correctly) so I can sell it.
evil will always triumph
have u replaced the air filters???
greasemonkey
Discussion Starter #6
the air filters are brand new. ill give them a call
