Do you have the regular twin or carbon?shupore said:I have the twin disc and Its a great street clutch that can hold lots of power. The pedal feel is very close to stock so it is easy to drive. My only gripe is the tranny rattle due to the lightened flywheel, but this can be solved by raising the idle to aroun 1krpm. Other than that, the light flywheel makes rev matching and aggressive driving really fun.
FYI, I had to order flywheel bolts from a 00' and up celica because the supra bolts are too long for the lightened flywheel.
Ya I saw your ad about this clutch but I can get the clutch brand new for less then you are wanting for yours. Does your other customer drag his Supra? I'm interested in how it holds up.racing fan said:I have a brand new twin disk that I need to sell... Another customer is making 840rwhp with this clutch and he has no complaints.
WOTM said:I think you don't listen very well![]()
Clutches are spend the money now or spend the money later, or waste time and labor inbetween. Two clutches will work for SURE at your HP level on the street and track and last for awhile. RPS CC and Tilton. That's it.
I have heard that the carbon does take more power but also needs to be warmed up before using ie a few slips before racing. Do you know about that at all? I'm coming up blank.irish100p said:Jerry,
I would reccommend the triple carbon, but the triple non-carbon should be ok as long as you're not planning on building anymore hp. The benefit to the carbon is it will take all the abuse you can throw at it and if it gets worn out it's only about 400 bucks to get it refreshed. Anyways that's just my .02
James
sleeknsilver said:exedy triple (metallic) seems great to me. very good bang for the buck since i got it for a pretty good deal.
i had the tilton and switched to this one. it feels almost just as slippable but i'm not sure how long it will hold up with multiple high RPM slips with loads of hp.
