1 - 3 of 3 Posts
What peice does the DP connect to? Is it a replacable part if broken? If it were broken would this result in an O2 sensor engine light? I am unable to boost my second turbo, which peice, if broken, would cause this? :wtf: TIA
T88 YOU
do you hear any difference at all when the second turbo is supposed to kick in? if not, there could be a problem with your vsv's. if you can hear the egcv open up though and you are not building boost off the second turbo, it could be seized.
Runs perfect in sequential mode, 1st turbo good up to about 8-10psi, then at 4500 I get a huge rush of air & the car boggs down & misfires. :eek4dance
1 - 3 of 3 Posts
