1 - 8 of 8 Posts
Hi guys,
I was just wondering, it is possible to use an existing muffler with a 2.5" inlet and covert it to a 3" inlet to be used in a 3" cat-back exaust?
Also, it seems like pretty much every turbo supra on here has a 3" exhaust, HOWEVER, almost every single exhaust guy i have talked to has said that there will not be any gains from going to a 3". Ive talked to about 6 exhaust guys, and they are all pretty convinced that the 2.5" stock exhaust is more than enough and that going 3" might even result in a decrease in hp due to the lowered back pressure. Are the exhaust guys that I have talked to correct?
Boostless
The exhaust guys you talked to are incorrect. There are significant, proven gains when upgrading to a 3" exhaust.
It would be possible to use a reducer of some sort to mate the 2.5" muffler to 3" piping. Similar to this:
Not so fast!
^ probably for you turbo guys.
I'm uneasy about going 3" on mine though, I might. But I'm considering 2 1/2" the whole way through.
But for turbo drivers 3" will definately show some gains. Hell someone I know driving an Evo I think went 3" and saw a 20+ hp gain with an ecu tweak as well... I think.
might've also ditched the cat for a test pipe.
7m > 2jz > 1jz
are u n/a??
or just dumb??
3" full system straight through no cats gives u a huge gain. over the stock 2.5".
-sean
ps.
ur exhaust guys are stupid!!!!!!!
SUPRAF0RUMS TROLL
there are wayyyy too many exhaust threads... SEARCH... and you will find everyones opinion... now... the bigger the diameter pipe... the more HP
Powderin my balls since07
for turbo cars...3 inch is proven to give u more horse...for NA it may not be tha best idea...search and u will find...
1 - 8 of 8 Posts
