1 - 20 of 38 Posts
single 1j
im a bit confused how you guys are talking about the accurate adjustment of -2.5 off the exaust cam. when i remove the timing belt, which way do i turn the exhaust cam if i'm facing the motor? do i rotated the exh cam gear counterclock-wise a tooth to have the -2.5 degree effect?
adjustable cam gear?
JZA is best f**k the rest
PM-Performance said:
You make all MKIII owners look great with that comment
:wtflol:
1 HKS Adjustable cam gear is $125, if you can't afford that, I wouldn't mod anything thats about the cheapest bolt on mod there is.
single 1j
Discussion Starter · #10 ·
ahaha. this whole time i thought you were soppose to just slip a tooth from the gear. i guess i'll be ordering those hks cam gears
Moderator, l337 M0d3r4t0r
I can do that I have the cams and cam gears just too lazy to test all this dyno time is hard on the car and expensive on the wallet!!!
Anways, I have titan gears.
So since we're on the subject of cam gears (plus the search function is acting up again) what were the cam gears NOT to get? i.e. teeth wearing down. Was it the HKS gears with 3 bolt or 5 bolt pattern?
HKS = 3 bolt
ranger2339 said:
Did you come from the civic community??ha ha...
Josh
DSM community LOL. I dont wannt to look like an idiot with only one adjustable cam gear if I only need one. I definatly dont want to buy two if I dont need to. Are the adjustmants the same if running 2j cams?
1 - 20 of 38 Posts
