anyone know what size thread tap is needed for the exhaust studs into the head? I thought it was 7/16 but i think its a bit too big. The search tool isnt working either.
oh i agree98mkiv said:pretty sure it's an M12x1.25. If you are replacing a stud because it pulled out, be sure to use a helicoil. Get it right or the remaining options are not pretty.
Using an english stud with a metric car, is OK, it will work, but whoever works on the car after you will curse you, especially if you only do a stud or two, not all of them.
Go to www.mcmastercarr.com and you will have a tap tomorrow morning. They also sell helicoil kits. If you are really in a rush though, most autozones, etc all carry these, prices aren't too bad either. I suggest helicoiling. Cleaning up threads rarely works if they are weak. When tapping be sure to drill the proper pilot hole and use a thick lube (diff oil) when you tap. If you havent tapped before, keep in mind:
drill the hole straight (perp to the head)
-mark the bit so you don't go deeper than you want(tape, sharpie, etc)
-lube the tap a lot
-be sure you have some way to hold the tap so it is perpendicular to the hole. The tap won't follow the hole if you are doing a shallow tap, so you have to guide it well. Also, don't wobble it or you will have weak threads.
-turn 1/4 turn in, then back off to break the chip. turn 1/4 turn in, then back off to -break the chip. repeat. Backing off means, just back off a little, you will feel the chip snap off.
-clean the lube out, and insert the helicoil or stud.
-follow directions for breaking the helicoil tang off....
and you will be golden![]()
Sweet, thanks
