1 - 3 of 3 Posts
Hey guys I'm goin go be changing out my exhaust manifold gasket because there's a leak from there and I'm going to be doing the studs while I'm at it. I wondering if there is any thing else I should do or look for while I have the manifold off the car other then just making sure the head isn't damaged in anyway. Thanks for any help.
Master Shit Fixer
Replace the nuts that hold the exhaust manifold onto the head too. Use PB Blaster to loosen those nuts. You'll need a Torx socket to get those studs out...I think it's an E8.
Okay thanks. Do you know if there is a way I can clean the exhaust ports a bit because I'm going to assume that the ports are going to have a nice amount of carbon on because the previous owner has the car tuned very rich right now I haven't had time to get it retuned yet.
1 - 3 of 3 Posts
