1 - 8 of 8 Posts
Stock Boost SUX
1.5JZ Turbo Supra
bad afm? Im not sure either thats weird tho. Idles ok then goes to shit when gas is added. Glogged fuel filter? pump going?
Stock Boost SUX
AFM works, fuel filter is new, pump is as well. SUX
1.5JZ Turbo Supra
umm throw some fuel cleaning system in their maybe injectors are a bit clogged or lines.
when this baby hits 88mph
wow that sounds terrible.
id pull the plug wires one by one and see if you can narrow it down to one cyl. if not you can do the inj one by one like badboy mentioned and see if you can narrow it down that way.
that will be a good start. post up what you find out.
good luck
dave
1 - 8 of 8 Posts
