1 - 3 of 3 Posts
Hello, has anyone had issues with the brackets for the rear mounts on the F-LCA’s bending? Were you able to bend it back okay?
I hit a tire wall at the track and now they’re bent. The brackets appear to be wielded to the suspension cross member. So I would need a whole new cross member if I want to replace them. Or custom make new brackets.
The brackets are more bent on the side that didn’t hit the tire wall.
251921
251922
251923
251924
you could bend it back and run a bead behind it to give it more strength. def have to go through the entire suspension and see if everything else is ok.
Thanks for the suggestion! The rest of the suspension held up really well surprisingly. I am planning on replacing some of the bolts and ball joints anyways. Just to be safe.
The impact was bad enough to shear the threads out of one of the Megan engine mounts. So the stud can’t thread in.
1 - 3 of 3 Posts
