1 - 4 of 4 Posts
Ok guys so I got my locks to work today and my alarm went off....the thing is I was trying it out and I locked the passenger door from the inside...then I locked the driver door..I took the key out put it back in and it went off...it won't shut off does anybody know how to disable it.I need it to work though
To disable you lock and unlock the driver side door with the key and the door closed. I have completely remove the factory alarm form three supras because they are so annoying. All you have to do is remove the alarm module located under the steering column, it is right above the gas pedal if I recall correctly and I believe it says security on it.
You will have to run one of the wires to ground, you will need a small piece of wire, a ring crimp connecter to go to a chassis ground and another crimp connector the crimp you pigtail to the wire that grounds the ignition ( the security computer usually does it).
1 - 4 of 4 Posts
