·I am installing aftermarket 4 channel amp for a friend in his mkiv and am wondering if anyone knows if there is a kit to hook up the factory double din deck to this amp....(something to convert the factory 7 channel low level wiring harness that goes into the factory amp into rca connections) for the new amp.
I did this same install in my car but I had to custom wire each of those 7 low level wires into RCA plugs to make it work.
Those high to low level converters do not work right either as I tried that first.....the reason is because the factory wires are already at low level!
Anyone with ideas please help! Factory deck to aftermarket amp converters?
Here is a picture of my amp.
