Thanks... the car has trapped 145 and some change.. a few times.ScrewDrvr said:Wow, ose are some impressive times. I didnt think anyone was in the 9's on the stock longblock.
Espeacially impressed with M Millers 143mph trap speed.
M Miller said:Thanks... the car has trapped 145 and some change.. a few times.![]()
silvino said:I thought you had cams?
ScrewDrvr said:How much mph do you figure one would loose from lets say, dblegle trapps of ~145, with the stock cams?
I would be more than happy with a 6spd 74gtq, on the stock longblock and cams, that could trap 135mph. On the stock ecu also, with only simple afc controls. Possible?
I think your wrong, last i read DaveH (trannygod) had an HKS 264 intake cam,..Brown Duckz said:I think DaveH is in the mid 9's on stock motor?
no its not only to yousilvino said:Ahh ok. I was only clarifying because to me stock longblock is stock cams too. People are using the stock longblock term too loosely.
30-32psi.. Yes, the old alphabet soup.phorcefed00 said:M Miller, how much boost to go 145 on the 74mm with 264s? That sounds like a killer setup for street & track! Also, how high do you rev it? I'm assuming VPC/GCC/GFORCE ECU?
