I'm going to be using the original head bolts as this is a non turbo and will have zero performance mods. I've got two engines worth of head bolts and was able to choose only the ones that were perfect. I will commit to a head retorque, however, just as a data point and to satisfy my curiosity. I've cleaned the threads in the block and they all felt good and looked good. 72 lbs ft of torque and lightly oiled threads with 30wt.
So, the cam cleanup paid dividends and reassured me that on the first go around I did not take off material beyond what was absolutely needed, as two needed a bit of a touch. The journal caps were so chowed. I used a perfect size tube with 1200 grit wrapped around it to knock off the high points of the damage, guided by the blue dye as to when to quit. Then a dremel with a 400 grit scotchbrite like pad for a very light touch to radially clean out the grooves. This allowed me to see a half dozen additional embedded tiny flakes of harder metal which I popped out with a dental pick. Finally, again with a very light touch I did 45 degree cross hatching to help with oil retention.
Goal was to keep material removal to an absolute minimum, while making the cam/journal surfaces more friendly to maintaining an oil film, while knocking off the high spots.
After that, I lined them up, shook my head that anything that bad can go back in a motor and survive, and mentally moved on to the valves.... Here's a picture of the caps now:
As I type this, the valves are sitting in Berrymans to dissolve the carbon, and the head is slathered with oven cleaner, and strapped to a hitch carrier in my LandCruiser. In an hour, I'll sneak over to the hand spray car wash place and pressure wash the thing and see if it gets the job done. Worked well on the combustion chamber side, this time I've filled the ports and the valve guide area.
