I was checkin out the latest Super Street mag and saw these new Fire Control Ignition Systems - Jacob Electonics. I was just wondering -
1) Are they any good?
2) Would they work on an N/A Supra
3) What would be the best ignition system you can get?
4) What all does each model of FCIS give that the previous doesnt? (Ex - FCIS 1000 // FCIS 2000 // FCIS 3000) and which would be appropriate//compatible with an N/A Supra and would be the best for it. Thanks
RoB~
« f ï z z | ë »
i believe thomsoncharm and oliver has the jacobs ignition... by the way, what ever happened to oliver?
I put up BS Flags
I got the Jacobs Electronics System installed in my car. When i did the install i replaced the plugs and got new Magnecore wires and it runs much smoother and you can tell a bit of a difference. So yes they do have a system that works for the NA Supra just ask for it if you get to their web page or get a phone number. As far as the difference between the systems im really not sure.
Later
King of the NA-T's
I have the HKS Twin Power ignition. You can get a plug-n-play harness so you don't need to cut any wires (kinda nice). After installing the ignition my idle was much smoother (I run cold plugs gapped pretty narrow). I haven't had any troubles blowing out the spark running high boost and nitrous... So I'd say it is a pretty decent unit. Not sure how it would compare the the Jacobs ignition, I've read good things about those too.
so you think the HKS system would be easier to install?? and which is better? *for those who know* and if I could also get a price that'd help a ton thanks,
Rob~
