1 - 20 of 83 Posts
Sup guys,
This is my last build for a while, but will be done right!
Car:
1990 Supra Turbo
Midnight blue/ Blue interior
Engine:
2JZGTE (DONE)
Polished crank (DONE)
Hot tanked (DONE)
New freeze plugs (DONE)
decked/milled (DONE)
blueprinted (DONE)
Stock rods/pistons (DONE)
New rings (DONE)
Clevite bearings (DONE)
New oem hardware (DONE)
New seals (front/rear) (DONE)
Head fully cleaned/ resurfaced (DONE)
New valve seals (DONE)
stock valve-train (DONE)
Stock cam
DM Pulley set
USDM water pump
OEM haed gasket kit (DONE)
Turbo system:
76mm Turbo (DONE)
SS T4 manifold that's been fully port.polished (DONE)
DM 48mm Wastegate
4" down pipe
CXR BOV
3 1/2" x 26 x 14 FFIC
All alum hard pips with 5ply couplers
Transmission:
Fully Built GM TH350 With trans break
GM-2j Adapter plate (DONE)
Stock flex plate
3600 stall TCI converter modified/balanced to bolt to stock flywheel :)
Custom 1 piece alum driveshaft
Custom transmission mount
B&M carbon hammer shifter/cable
Fuel System:
Oem Tank Sumped and fitted with -10 AN fittings
SX 18207 External fuel pump (120GPH) (DONE)
SX Stainless Fuel filter (DONE)
Custom Top feed fuel rail
Precision Turbo 1000cc Injectors
Aeromotive FPR
All steel braided lines (-8 feed)(-6 Return) (DONE)
Running e85
Engine Management:
AEM EMS v1 (still in the works)
AEM 5bar map
AEM IAT sensor
AEM Eugo wideband
AEM Tru boost
Twin DLI setup
Suspension/Brakes:
KYB GR2 struts (DONE)
Eibach pro lowering springs (DONE)
Brembo Rotors (DONE)
Cooling:
CXR Aluminum radiator
Twin Electric fan setup
Wheels:
Greg Welds
Rear = 15" x 8" wide (DONE)
Front= 15" x 3 1/2" wide (DONE)
Tires=
Rear= Mickey Thompson E.T streets 275/50 (DONE)
Front = MT reg street 185/60 (DONE)
Enough talking and more pics.
As of now, yes. But later on this summer i will be doing a rear seat delete with some spearco seats up front.
Some update,
Recieved these
Should have them on tomorrow.
Some update,
I got these parts installed
And a quick test fit of the wheels with the new suspension/brakes :)
· Captain Slow.
SICK. post your setup in the MK3 drag radial/slick thread. in the mk3 section
I think i have already posted in it, cant find the link though. This is the same setup i had on my gray car.
Discussion Starter · #10 ·
did a little freshening up today, you can see the before and after side by side :)
Discussion Starter · #11 ·
ugh, not too good of a start this morning :/
Was walking out of my house and found this,
Somehow it fell out of my car or something, and got ran over a couple times in my driveway. silly me, that was a waste of money.
On the bright side i received more parts.
T4 manifold
ARP Head Studs
Oh and here is the finished product of the valve covers with a better camera.
And also forgot to post a pic of the 76mm :)
Discussion Starter · #12 ·
Just ordered my th350 adapter from SP, cant wait to get it :D
Discussion Starter · #14 ·
What did you do to your vc? Paint?
Sanded, degreased, power washed , prepped with alcohol, 5 coats of engine paint (gray) and 5 coats of high temp (clear). let sit over night. voila :)
Discussion Starter · #15 ·
should have the motor dropped in her within 2 weeks.
Here is the pump/filter and lines. Also picked up a cute little fire extinguisher lol
Discussion Starter · #17 ·
Thanks to the guys at SP, I received my trans adapter today after ordering it yesterday!!!
Should have the trans tomorrow.
Discussion Starter · #19 ·
Thanks, picked up my trans today, (will post pics later)
Tomorrow I will be picking up my J3 bell housing/ flex plate and drop the trans off to get the bell housing chopped off :D
Discussion Starter · #20 ·
Update,
Picked up a J3 bell housing for this adapter and flex plate all thanks to brandon (enslaved87)
adapter bolts up perfect !
My built TH350 that will have the bellhousing chopped off soon, (taking it to my trans guy tomorrow)
And last but not least i got a good start on my wiring , I'm taking my time on this so i should have it done in a few days.
1 - 20 of 83 Posts
