Z
Zerosoul
·Guest
had Bruce Nomura help me install a HKS fuel pressure regulator, Fuel pressur gauge and finally fixed my problem.
I EGT was shooting up to 760C mounted on top of DP, running 18psi BPU which was way too hot. I suspected a really lean fuel supply and decided had some helpful inputs from Grant and Andi and other guys on the forum. After I had the fuel pressure dialed in correctly, my EGT droped to 690C MAX in every hard pull even on uphill.
so for those of you who have high EGTs, check intoyour fuel presure regulators and fuel pump to make sure you have enough pressure in fuel.
Jonas
Jonas
