1 - 17 of 17 Posts
i live in minnesota and need to find somthing a little higher octane that 91 :rolleyes:
What about at the airport?
they said if i pay the $25,000 fine in advance i can buy some. :wtflol:
I've never been to a drag strip that didn't see racegas. In MN you have Brainerd International Raceway Brainerd, MN; Grove Creek Raceway Grove City, MN; Interstate Dragways Glyndon, MN. If you're near the border with other states, check those, too.
If all else fails, order a small drum from VP Racing http://www.vpracingfuels.com/vp_01_fuels.html
how long would gas keep for. would it start to loose its quality if it is un used for to long?
Driver Down
Fuel seems to lose potency EXTREMELY FAST. That's why a lot of people add fuel stabilizer to the gas they use for their lawn mower. Even sitting for a short period of a month can affect it.
However, take what I say with a grain of salt, race gas may be different, I don't know...
i am thinking that if i buy the 5 gallon sealed containers maybe it would keep longer?
Driver Down
Keep it sealed, I believe gas is hygroscopic, as in readily takes on and absorbs moisture. In know Alky is REALLY sensitive as it draws in water faster than a spilt glass of water in the middle of the sahara.
But 5 gallons probably won't be sitting around as long as say, someone who bought a 55 gal drum of it, so I don't think you have MUCH to worry about. Just don't let it collect dust or leave it unsealed :)
Alpha for president
I've had a 55gal drum of c16 for about a year...it's still good...but like someone said before it has to be sealed good....
I bought a 55gal drum of C16. You must seal it tightly after you open it first off, second you have to keep it from sitting on the ground. I sit mine on two 2x4's. You don't want it to condensate from sitting on a cold concrete floor since that will increase the chances of water in the fuel. A drum from VP has been known to last upto 2 yrs or more since they use lined drums and of course keep the seal clean and in good shape :)
Discussion Starter · #12 ·
would temp effect how long it will last we can see -30 or colder in the winter. also would the fact it is leaded or not make a diffrence?
Discussion Starter · #13 ·
can i get a 55 gal shiped to me and how much$ ?
That's some pretty cold temps but i'm sure if you keep it inside you should be ok. Might want to check with VP for sure though. I get my fuel from a local motorcycle shop. I get a decent price and he orders me a drum when he's restocking. Might want to look there is there is no other place for you.
I just ran some C16 in the car for the first time, nice results. I go to a car shop to purchase it. I only have a 5gal jug though.
its a slow auto...
why would you want gas from the airport? its made for planes, not cars ....it usually has alot more lead in it and has a different burn rate then automotive "race" gas :)
Cheifbootknocka
You can usually get race gas at motorcycle shops too. Or they can tell you where to get it.
1 - 17 of 17 Posts
