Garage Queen Club
Anyone experience this issue? The AEM shows my FJO wideband signal fluctuating every 100ms .4 AFR (the gauge reads steady). Are there sensitivity adjustments I need to make on the AEM? I've tried two ECU grounds and one chassis ground with no difference. The AEM readings seem to track properly, but I can't get a solid reading ever.
Have you been able to monitor the voltage output from the FJO with a scope or some other unfiltered device?
Are any other sensors on the AEM stepping like this or just the FJO input?
Garage Queen Club
Just the FJO. All other sensors are solid. Let me hook up my scope right now...
Garage Queen Club
Solid on the scope. I'm using the FJO LEGACY output (non linear). Not sure what the AEM Wizard configures to, since the FJO has a second tan wire output which is .5v~4.5v curve.
