Anti-freeze: Toyota Red
Diff oil: Mobile 1 Synthetic
Brake Fluid: Castrol GT LMA DOT 4
Auto Tranny: N/A, I have a 6-speed :)
Others will have different opinions but these above brands have done me well in the past.
I would use Mobil 1 10w-30 in the engine, Toyota Red Antifreeze, Mobil 1 or Redline in the Diff., Motul Brake Fluid, and ONLY and I can't stress this enough, Toyota T4 Automatic Transmission fluid. Using anything else in the tranny will serverely shorten the life of the transmission.
Zeeshan said:
Hello,
Fluids like
anti-freeze, differential oil, brake fluid, Tranny (auto) fluid etc
any recommended brands?
94 TT
ANTIFREEZE TOYOTA RED PART#00272-1LLAC-01 $14.95 GALLON
ATF FLUID TOYOTA TYPE 4 PART#08886-01705 $24.95 GALLON
6SPD GETRAG TOYOTA V160 PART#08885-01306 $44.95 QUART
ENGINE OIL CASTROL SYNTEC 5W30 PART#79191-00067 $4.95 QT
REAR DIFFERENTAL CASTROL GTX GEAR OIL 75W90
tranny fluid: toyota sell them in 4 liters container.ATF Type T-IV ~$30 each. You'll only need about 2L to flush the tranny.
has anyone done the gear oil change? do you need a special pump? was it easy?
