My fluidyne is only leaking from the drain plug (i thought), but since you guys are having problems w/ the sensor, I will check that out tomorrow.
I've got the drain plug torqued down so far that the body of the nut is almost touching the radiator. Chip, ur plan may work if I can get it down a little further, but am scared because the bolt seems tightened waaay beyond normal. Tomorrow Im going to try the teflon and see if that does the trick.
Mr94supra,
Are you saying that your radiator is leaking now, and you have teflon on your drain plug? Did you check it out to see if it is in fact coming from the plug? How many miles have you had tape on there?
Grant,
How many miles has tape been on your bolts? You road race too correct? Do you often change your coolant and replace the tape or has it been there for a while?
Thanks for everyone's reply. Im just trying to see if the tape can take to the heat and mileage I put on the car. Also, is it just me or is this a problem that fluidyne should fix in the future?
tia, sorry for long reply
-chris
