1 - 7 of 7 Posts
On the top of the radiator it could be easily done by welding a screw nut on it. What`s about the form of the radiator? The original one is
rounded, the fluidyne is edged.
Of course you can modify it to work...but you didnt ask that.
Master Shit Fixer
It didn't fit my Mishimoto's edged top, so I had to ditch it. I even considered modifications, but none would have worked. I think only a rounded-top radiator will accept that snorkle.
Discussion Starter #6
Just would like to give you a feedback. It fit by pull down a little bit an by weld a nut on the radiator
Koyo has the nut welded and the OEM air box channel bolts up.
1 - 7 of 7 Posts
