·I have done the rewire exactly as follows on SOGI (if unfamiliar, please resort here: http://www.supras.com/04/resources/index.php?id=42&start=31 ).
Here is my best explaination to what I did:
- Under the section Rewire the foglight switch, I snipped the red/green wire and taped the end going ot the wire harness. I attached a screw-type connector to the switch end of the wire. I then cut the white/black ground wire to the rear defrost in half, stripped, then binded the wire back together and put it in the other end of the screw type connector
- Under the section Rewire the foglights relay, I verified I had the correct relay as indicated and cut the red/black wire. Using the same screw-type connector as above, I attached one end to the red/blk wire that goes to the relay and an extension wire to the other end of the connector. I then routed the extension wire to the 7.5A "GAUGE" fuse.
Now my fogs dont come on at all. What the hell??? Is there an easier way to do this or did I mess up on something? Any help is appreciated.
