1 - 16 of 16 Posts
Are the bolts the same for the auto and manual?
If not where can i get some that aren't 8$ a pop.
-ian :sadance:
Senior Member
:rolleyes: They hold your friggen flywheel on for christsakes.
Don't cheap out and buy the proper bolts. All that for maybe 20 dollars of savings?
Give me a break.
fyi, these are supposed to be direct replacement Flywheel bolts.
same pitch thread etc. & they are ARP.
Im down with buying yota parts, but if ARP's been in the game doing what they know how
I am cool with saving some stealership $ and buying a high quality part.
Fat Guy in a Little Coat
Agreed..I used the ARP bolts when putting in the rps carbon/cabon and saved about 40 bucks on bolts.
Are these bolts replacements for the MKIV? If I known I would of brought these instead. I wonder Y MVP don't carry these.
Discussion Starter · #10 ·
these bolts are going into my 2jzgte, i.e. direct replacement for any car with a flywheel and 2j motor... maybe add these to a sticky of parts you can get that are as good or better than OEM and not as expensive.
yes...direct replacement.
bringin back an old thread
These bolts are for the 4A-GE, they dont look near long enough for the 2JZ-GTE, can i get a confirmation these fit
Is it turbo? Is it stick?
never heard of this until today. interested to know if they fit properly. they dont look like they come with threadlocker on so be sure to use some on the bolts to make sure they dont back themselves out over time...
Seconding... its crucial to use threadlocker on bolts like these... one backed out bolt and it will really mess everything up.
you dont need thread lock or locktight on ARP bolts if you use the ARP assembly lube. has anyone used these bolts on a Supra yet?
1 - 16 of 16 Posts
