I think the point you are forgetting is that the stock ecu uses more than just rpm inputs to determine fuelling and ignition timing. Obviously, the other huge factor is the MAP sensor.
E.g. where you say the ignition timing ramps up as the turbos come on boost at 3000rpm, it would be doing this because it is at X on rpm scale and Y on MAP scale. When you install your larger turbo you will still be at X on rpm, but Y -5psi on the MAP scale.
Also, I am not sure where you are getting this info. from but from all reports timing is at its lowest (most retarded) at peak torque which would be around 4500-5000 on a stock twins 1jz.
Everyone knows what the answer is. Aftermarket ecu
Can do a lot more fiddling to get it all right there.
BTW why do you say that the ecu ups timing enough at 4000rpm to get the gt40 spooling? I think you will find that the major contributing factor to that is the physical size of a t4 exhaust housing compared to ct12a's. (even with .68 a/r)
I have a fair few timing maps of different 1jz turbo combinations but the biggest is a GT35 .8 a/r so can't compare directly.
