Needs More 1jz
Since search isnt working for me.......again anybody got the pic or the link on how to remove the front bumper?
Thanks, Barry
bolts tons of them
Needs More 1jz
well yea i figured that my problem is i dont wanna risk breaking bolts i might not have to take out so seeing how i can attack the problem before i do so is a safer way in my mind.
1-) Remove the front grill
2-) remove the turn signals and fog lishts
3-) Inside the wheel well on both sides, there should be 3 screws. takem off
4-) you should fin 2 screws where the grill/ signal light come out at
5-) unscrew the under carraige part ( under both side of foglight, there is a cover on the bottom, unscrew those
6-) there are 3 screws where you take the bottom grill out
that should take the shell out (bumper cover) then once that is out, you can easy unbolt the bumper support by just lookin at where it connects since you can see everything then. :bigthumb:
correct me if i for got a few, i think i pretty much covered it all.
goodluck
Not so boring anymore
looks about right.. just pulled off everything on the front on my new car to get the bay painted.. its a pita.. but worth it when done :)
Needs More 1jz
thanks guys i figured since i cant get the lip off the red car to put on the white car ill just swap the bumppers before paint!! :)
