how hard is it change the front crank seal and timing cover seal. these two seals is what is causing my massive oil leak. does anyone have any info on these
if your doing crank seal and timing cover seal, it'd be pointless not to do the cam seals while u right there as well as the water pump, its all right therer u might as well if u got $$ for parts. carefull not to turn cam or crank to disrupt timing, or retime it if you know what your doing. other then that i think ur aiite,
watch those keyways, and I just did my front main, didn't touch much else while I was there (had to replace the timing belt idler pulley, crank timing pulley, timing belt, and front main...)
all started because the idler pulley went out...
