1 - 12 of 12 Posts
ic
thanks...i have all apex stuff...intake, bov and boost controller. and egt oil and boost gauge with apex n1 exhaust.
Poser Extraordinaire
I have an Apexi FMIC, its bigger than the small HKS type-S but smaller than the Greddy FMICs
The only problem is that it hangs kinda low
Ting
I finally completed the IC installation. The intercooler practically hangs below the stock front lip! and the drivers side piping is inches from the ground. Not 100% happy with this kit. The piping is difficult to line up also..
Discussion Starter · #10 ·
I have the Greddy 3-row on my Auto TT and like it alot. Fit perfect and the hard pipes look great. The Apexi only has the lower hard pipes and I believe if you plan on putting a large single turbo on your car, the Apexi will not be big enough.
The auto trans cars has a factory front mount a/c cooling fan assy.in front of the a/c condensor.
I know with the HKS type R FMIC (part #1301-RT066+ size 600mmx302mmx97mm] you cant use the factory fan set-up.
My question is :if you use the Greddy 3 row or Apexi FMIC, can you still use the factory cooling fan ,or does it have to be removed?
I have a 98TT 6spd and the fan issue wasn't a problem for me.
{TT 6 spds don't use aux. cooling fan}
Discussion Starter · #12 ·
I'm not sure about the Apex-i, but I know that you have to remove it to put on the Greddy. I would imagine that you would have to remove it for the Apex-i as well.
1 - 12 of 12 Posts
