1 - 10 of 10 Posts
What tire size should I run to avoid front rubbing?
18x9.5 +27 (245/40/18) Any help is appreciated 馃憤馃徏
246029
246030
Boost Junkie
245/40/18 is a 25.84 inch tall front wheel/tire combo. That is too tall. The factory size is 235/45/17 is a 25.46 inch tall combo, so you're taller than the stock. Most guys run a 265/35/18 front wheel/tire combo, which is 25.42 inches. Believe it or not the extra .4 or so inches in height that your combo has makes a big difference up front. Are those Supra specific Work wheels? The offset looks like it is poking out a bit.
You may want to try a 255/35/18, which is a bit shorter at 25.14 inches. That will allow you to lower it a bit and that will pull the tires/wheels into the body more.
Steve
I bought these off a buddy definitely not Supra spec. Sits pretty flush with the fender. Hopefully that helps versus having to change suspension.
Thank you Steve!
Boost Junkie
Next time I would only purchase wheels with the correct offset.
Steve
Master Shit Fixer
Depending on your spring rates, you may be lowered too much also. Is your top fender bolt removed?
From the land down under
The wheels offset is not suitable for the car, and is causing your rubbing problems.
I run a 255/40/17 up front and have never rubbed, but I have 8.5 +40 wheels, which are suitable for the car.
Master Shit Fixer
The title of this thread sounds like a CraigsList ad for sexual favors.
You may want to try a 255/35/18, which is a bit shorter at 25.14 inches. That will allow you to lower it a bit and that will pull the tires/wheels into the body more my ip birthday wishes tneb .
Steve
1 - 10 of 10 Posts
