Status
Not open for further replies.
1 - 20 of 33 Posts
Email: [email protected]
City: Porter Ranch
State: CA
Zip: 91326
Phone: 310-6seven8-one87zero
Price: $28,500
Silver Bullet approved.
Tired of seeing the car just sit in the garage. Was purchased 6-7 years ago (at least - I don't remember) bone stock tt supra aside from the side skirts which I believe were added on, so I am the second owner and it has 174,xxx miles and I believe I bought it with around 142,xxx miles. Car is originally from Florida. Never has been in an accident under my care and had a clean carfax when it was purchased. Car was painted flat black because of the clear coat on the hood starting to peel off - Plastidip was a cheap and nice (to me at least) alternative. Car made 520 whp on 91 gas and 620 whp on race gas. Didn't want to push it higher at the time due to having higher goals and not wanting to damage anything even though it probably could handle more power.
Feel free to text or email me for pics and dyno pics.
Only thing I can think of that I would fix would be to change the coil packs or switch to some sort of other coil packs. I've been reading on this forum that others have had breakup at the top end like it did on the dyno and that was probably the reason why. Motor sounded strong - it was just the ignition that had to be addressed.
Audio
Alpine CDA-9885 Face Plate
Alpine MRP-M450 Amp
Alpine Type R Speakers
Kenwood Excelon KFC-XW1200F Sub
Pioneer Premier PRS-D3000SPL Amp
Engine
Greddy Oil Filter Relocation Kit
Greddy T88 Turbo Kit With Garret 4094R (67.8mm compressor inlet, 94mm compressor wheel outside diameter and 77mm turbine wheel) turbo instead of T88
Greddy Type R BOV
ARP Head Stud Kit
Brian Crower Springs & Retainers
Cusco Oil Catch Can
HKS SSQ BOV
HKS Intercooler
Power Enterprise Timing Belt
Earl Cooler for Transmission With Spal Fan
B&M SuperCooler for Power Steering Fluid
Power House Racing Upper Radiator Pipe with Sensor Fitting
Fuel
Aeromotive Fuel Pressure Regulator
Aeromotive Fuel Filter
PHR Fuel Pump Insulating Wrap
750cc RC Injectors
255lph Walbro Fuel Pumps x 2
HKS Fuel Rail
Okada Plasma Booster
Drivetrain
Boost Logic Transmission with 3800 FTI Stall Convertor
OS Giken LSD (Just Installed!)
Exterior
Greddy Lip
Tanabe Touring Medallion Exhaust
VIS Carbon Fiber Hood
Do Luck Side Skirts (Not sure they came with the car)
Whale tail spoiler
Aerocatch Hood Locks
Glass headlights
Interior
Sparco Torino Seat with Sparco Bracket
Power House Racing Shift Knob
Wheels/Suspension/Brakes
5Zigen SC3000 Wheels (8.5x19F and 9.5x19R)
Tein SS Coilovers
Nitto Invo Tires
DBA Rotors (Forgot which pads but they were a good brand)
Stainless Steel Brake Lines
Electronics
AEM V1 EMS
AEM Bar Map Sensor
AEM Boost Control Solenoid Kit
AEM UEGO
Greddy Boost Gauge
MaxiGauges System - Oil temp, oil pressure, transmission temp, fuel pressure, water temp, voltage
Extra Parts
Lexus Union Bolt with Pressure Sensor Fitting - 90401-19008 Union Bolt, 90430-20016 Gasket, 90301-68005 O-ring (Optional)
Sparco Steering Wheel with bracket for buttons (horn etc)
Stock Driver Seat (Needs to be reupholstered)
Stock Transmission
Stock Fuel Rail
Stock Front Tow Hook
Stock Underside Front Panels
Stock Ash Tray
Stock Dash Panels (All 5)
Stock Springs & Retainers
Supraforums GB Sun Shade
Supraforums GB Floor Mats
MVP Motorsports Timing Belt Tensioner Bracket / Kevlar Racing Belt Combo
Stock Hood
Promotional Booklet, Sale Sticker, etc
Stock Valve Cover Gasket
Stock Coil Pack Connectors
Stock Spoiler
Toyota Emblems in Black (Hood/Trunk Ones - Hated the gold but it didn't matter since I painted over them)
And a LOT of other junk just sitting in boxes
ALL 12 vin stickers can found on this car as listed on speedforsale
Discussion Starter #3 (Edited)
Didn't know you could upload from the phone. here are the pics. Rear diffuser is gone in last pic. If the hood paint looks off its because I did the stock hood and the car at the same time. Bought the aftermarket one afterwards and just sprayed it on my own. Forgot that the whale tail is also on the car I will update list of it lets me.
Willow Springs Day
Discussion Starter #12
Sorry for late response. Only the hood showed the clear coat bubbling/peeling from the temperature. Rest of the body was fine.
Maybe I should mind my own business here but thought I'd drop some advice. I've seen this car listed for quite some time now.
My opinion...
Take the plasti dip of. The matte black isn't very appealing to the eye.
Take some better pictures. If you look at the pictures you posted you can see the rims horribly dirty in one. The other one of the interior shows a bunch of garbage on the passenger side floor. Gives the perception of a dirty car although it might not be.
Just trying to help. Good luck.
1 - 20 of 33 Posts
Status
