1 - 14 of 14 Posts
Wishes I had a Supra
What is your First & Last name? Camilo Torres
What is your email? [email protected]
What is your phone number? -Optional: 702-439-2176
What is your City? : Las Vegas
What is your State? : Nevada
What is your Zipcode? : 89149
Ad Description:
I am selling my AVC-R complete with everything in the box. I will sell it for $300 shipped . They are $500+ new , mines used but like new.
Desciption below:
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.
The AVC-R also uses a highly durable, fast action solenoid valve to physically control the boost . The valve movement (Boost Duty Cycle) can also be modified. Raising the duty cycle increases boost response, while lowering the duty cycle will slow boost response. This feature allows boost response adjustment for varying turbo sizes. Since larger turbos take longer to spool up ( bad low end response) the duty cycle should be raised under lower RPM's for better response. The opposite should be done for smaller turbo's ( excellent low - mid range response, but limited top end power.) A'PEXi engineers address this issue by including extra menus for RPM based boost control. Drag racers may want to utilize the Gear based boost control function. Aside from the basic functions above, the AVC-R has a Start Duty Setting (allows the boost to momentarily overshoot according to gear).
The AVC-R also includes a Scramble Boost function which allows the user to momentarily raise or lower the boost level at the push of a button. Raising the boost level is commonly used when an extra burst of power is needed (ex. entering a freeway). This feature can also be used in drag racing. The driver can set the main boost level to a low setting for maximum traction then, once full traction is achieved, the scramble boost can allow the vehicle to boost full power.
The AVC-R displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. Peak Hold is also included in this function. The Graph Mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
Pics of it installed , More pics of everything out coming soon.
Discussion Starter #2
This is a very good boost controller and sells for over 500 new. ttt
still available. Boost controller has two setting you can run , setting a and setting b . So you can easily switch from low boost to high boost or vice versa. So many great features
...smell like cabbage
I would be interested in this... could you get it approved by a mod/admin? No offense, but no posts and no iTrader is a little sketchy even with your name in the pics.
Discussion Starter #8
I understand , I dont post here much cuz I dont have a supra :( . Supra is my dream car so I joined to look at sexy rides and stuff. How can I get a mod to approve? Here is where I post and where some of my pics came from.
http://forums.clubrsx.com/showthread.php?t=572108
go in the vegas section on clubrsx and everyone in there will vouche for me , also in the turbo chat thread.
Actually I'm probably going to go with the HKS ebc but you can get a mod to approve just by PMing them. Nice rsx btw.
Discussion Starter #10 (Edited)
Thanks. Doesnt stand even close to any Supra on this site probably. I currently have the fastest RSX on stock block running 91 octane though :D . I actually have faster times then some people with built motors lol . :D
check em out ! ! I know its nothing compared to Supras but one day I will get my Supra :)
http://forums.clubrsx.com/showthread.php?t=607254
1 - 14 of 14 Posts
