1 - 9 of 9 Posts
Certified Supra Nut :P
doing a little spring cleaning and I'm getting rid of some stuff I don't need. Most of this stuff is small things you guys might need but I don't, so get it here cheap, everything is plus shipping, figure most things about $5 shipped by mail most places unless they are heavy.
edit: I also have a brand new AEM EMS 30-1100 for a MK4 Brand new in the box, never opened or installed, $1,500 takes it. -- SOLD
I have a brand new centerforce clutch for 7M-GTE. Never even removed from the box, part number DF500100 centerforce wants $588, for it, I'll take $450 + shipping.
Here's some other stuff I have
Bosch BOV from Audi S4, $10 - sold
Polished turbo manifold heat shield. $40
The photos were taken with a camera phone and don't really show how shiny this thing is.
stock 7M-GTE air box $10
AC fans, $15 - sold
another set of AC fans, these came off a parts car, so I have no history on them, they are a little rusty. $5
CT-26 wastegate actuator, $10
stock AFM housing $5
stock bypass / BOV $5
charcoal canister $10
Discussion Starter #2 (Edited)
set of coils, $25
cold start injector $5
GTE turbo engine/coil cover, there's a small crack in the corner (pictured) $20
fuel feed line $5 - SOLD
fuel return line $3
89 intercooler, there's a dent in it, see photos $35
idle valve IAC $5
throttle linkage $5
maroon hatch sunshade, in poor shape, discolored a bit $5
GTE throttle body w/TPS $15 - sold
ct-26 turbo heat shield $15
Discussion Starter #6
How much torque should the dual friction hold?
Thanks.
centerforce says this about them
Generates a 90% increase in holding capacity over stock systems. This centerforce clutch/disc set is designed for use with engines producing high horsepower and torque output, and any radically altered high performance street vehicles. This centerforce clutch system is also ideally suited for use with four wheel drive vehicles. All Centerforce clutch systems provide smooth engagement and light pedal pressure without compromising high performance.
1 - 9 of 9 Posts
