**SOLD** Fastest/Quickest 4.3L GMC Typhoon in Colorado only $15,900!!
**SOLD**
Black/Black GMC Typhoon #1438 of 2,500 Quickest/Fastest 4.3L Typhoon in Colorado. ~500whp on 91 octane.
Only time slip at Bandimere (5,300+ft above sea-level) was 12.25 @ 107.81 w/a 60' of 1.71 on a bad ignition module that has since been fixed. I'm pretty sure it has 11's in it at this elevation which would be awfully close to 10's at sea-level. Keep in mind it did this on pump gas and all season tires and in full street trim which is 4,200lbs with me in it. In other words, it's one of the few vehicles that will run the exact same time on the street that it did on the strip. I've owned and been in many fast vehicles and this is by far the fastest out of the hole and even gives my street bikes a run for their money w/0-60 blasts in the 3 second range.
The reason for the sale is because I don't drive it much and can't justify it just sitting. Someone will get more use out of this than me and give it a good home. No day dreamers or tire kickers and no lowballers. This is one of the most solid cleanest Typhoons in existence so if I don't get what I want for it then I keep it. So, serious inquiries only. It would cost twice the asking price to bring any other Typhoon up to it's level. The engine has about 3k miles on it since the build including the drive back from MN where I purchased it. I have TONS of pictures of the build as well. I reserve the right to pull the sale at any time should I decided to keep it unless there is a deposit and I will NOT hold it w/o a deposit.
Interior
*5% tinted windows all around & tint visor on windshield
*Brand new embroidered floor mats front and rear
*Panasonic CD player DF602U (blue graphic display 50x4 w/remote)
*MTX Thunder 8500 12" sub & custom box/amp rack
*MTX 5000D amp
*Phoenix Gold wiring and breaker
*1 farad power cap
*DEI 2-way alarm system w/remote start, hatch pop, pain generating sirens & all sorts of other goodies
*Ultimate V9 chip w/Gauge sized display/control
*Autometer boost gauge
*EGT gauge
*Torque converter lock-up switch
*Walbro high flow fuel pump
*GReddy Profec B (Blue) boost controller
*Custom display (Scan tool hard mounted into glove box and display mounted above stereo, can be used to display four different sensors)
*Escort Passport 8500 w/custom hardwire install
Exterior
*Bosch H4 conversion housings w/Sylvania Silverstar H4's.
*Sylvania Driving lights
*Rear driveshaft loop
*Original paint (I was going to paint the hood as there are some scratches and what I would consider lots of rock dings on the leading edge... common for this body style since it's straight up and down)
*Z34 vents in hood
*Hood shock kit
*Lowered front and rear
*Factory wheels polished and inserts painted black
*Diamond/clear corner housings for side markers
Engine
*Stock block bored .030 over & all oil passages/drain ports were debured and smoothed out.
*Stock crank turned down .010 on the mains and .020 on the rods & micro polished.
*New L35 rods shot peened (sp?) for stress relief & machined to accept the Speed Pro floating pins.
*L35 heads slightly worked on the intake side and machined for larger springs.
*Ported stock intake
*Comp Cams springs
*GMPP billet steel 2 bolt main caps
*Z28 oil pump with welded pick-up
*Comp Cams double roller timing chain
*Speed Pro .030 over pistons with coated skirts
*Speed Pro rings
*GMPP 1.6 self align roller rockers
*ARP head studs
*ARP main studs
*GM head gaskets
*Stock cam
*Comp Cams push rods
*Edlbrock aluminum water pump
*Custom alternator bracket tensioner for a/c bracket removal
*Custom 3" down pipe with external wastegate
*B&M flex plate
*Turbo is a T3/T4 hybrid, 57 trim compressor wheel w/.60 a/r housing and a Turbonetics Stage V compressor wheel with a 5 bolt Turbonetics .63 a/r housing.
*MSD 6A
*MSD Blaster GM coil
*Taylor plug wires
*50# injectors
*Adjustable fuel pressure regulator
*TiAL external wastegate
*200amp alternator
*Air to water intercooler 86'd for custom Air to Air
*Razor progressive alky injection
*Optima RedTop
*Taurus (6,000cfm) Electric can w/Factory shroud
*GReddy Type R BOV (mounted at lower IC pipe facing down to avoid alky in engine bay
*A/C removed w/non-A/C heater box and custom bracket
*PermaCool power steering cooler mounted under the radiator
*Permacool tranny cooler w/10" SPAL high flow fan
*HUGE front mount intercool mounted behind factory grill
*Heat wrap on 3" downpipe
*Heat covers on plug boots
*Billet overflow catch can
*K&N cone filter
I'm sure there's more but this is all that's coming to me right now.
If you want to see full size versions of the pictures below you can go here (starts at the bottom of page 5) or delete the '.sized' out of the end of the url. Sorry for the dirty interior but I didn't vacuum it prior to taking the pics.
**SOLD**
Interior
*MTX 5000D amp
*1 farad power cap
*EGT gauge
Exterior
*Z34 vents in hood
*Hood shock kit
Engine
*Comp Cams springs
*Speed Pro rings
*ARP head studs
*ARP main studs
*GM head gaskets
*Stock cam
*B&M flex plate
*MSD 6A
*Taylor plug wires
*50# injectors
*200amp alternator
*Optima RedTop
*K&N cone filter
