1 - 1 of 1 Posts
The only reason that I am getting rid of these parts is because I am in the middle of a build and I won't need these parts. You can call me at 786-255-8612. Monday thru Friday I will be teaching classes so please text me. On the weekends you can call me.
3000 pipe- 10.00
Primered 1 Piece wing- 40.00
H4 conversion black housing projectors- 60.00
CT-26 Turbo (Little Shaft Play)- 160.00
7m-gte Radiator with fan, fan clutch, and fan cover- 60.00 (Pick up only)
EVAP canister-20.00
Yellow Connector GTE manuel ECU- 80.00
Yellow connector GE Automatic ECU- 80.00
Stock Exhaust Manifold- 20.00
Stock Fuel Injectors 440cc- 60.00
Stock Pistons and Rods w/ new bearings- 100.00 (Pick up only)
6m Crank- 80.00(Pick up only)
Stock Flywheel (resurfaced)- 40.00
Brand new W58 Clutch (never been used)- 80.00
W58 Transmission- 200.00(Pick up only)
Split driveshaft-60.00(Pick up only)
W58 crossmember- 20.00
EGR Valve Assembly- 20.00
ARP head studs (used torqued down to 80 pounds)- 80.00
Entire intake manifold- 80.00 (if split 40.00 each)
If you want pics just let me know and I'll PM them to you.
All Items are OBO. IF YOU LOW BALL I WILL JUST IGNORE YOU. Thank you.
1 - 1 of 1 Posts
