1 - 20 of 43 Posts
First & Last Name -> Austin Gray
Email Add -> [email protected]
Phone Number ->210-834-6158
City -> Clovis
State -> New Mexico
Zip Code -> 88101
The car is a 1995 S14 240sx.
Everything on this car is getting parted, if it's not listed I still might have it, feel free to ask.
The majority of these parts are brand new and installed on my project car, the car hasn't moved under it's own power in 3 years, being as close as I am I'm pretty much done with the whole car scene for a while and I feel like if I do finish it it'd only get me into a ton of trouble. So I'm decided to go ahead and get rid of a bunch of stuff from my build, I'll be updating pictures as soon as I can and add items I find.
Please note that since the majority of the parts are on the car it'll take me a few days to remove and ship.
Please add 3% for paypal transactions and whatever shipping charges may be.
The majority of these parts are new and haven't been used, only installed.
JDM 2jz-GTE cams - $75
Stock Cam gears - $25
NEW- Brain Crower cam gears - $185
NEW- ARP Head studs - $120
NEW- Induction Performance welded crank trigger gear - $95
NEW- Fluidampr harmonic Balancer - $300
NEW- Turbosmart Hypergate 45 - $300
NEW- Black Tial 44MM BOV w/10 psi spring - $200
2jz-gte AEM v1 - $450
NEW- Drift Motion 6465 turbo w/90 degree bend welded on - 675
NEW- Injector Dynamic 1000cc injectors 14mm - $600
NEW- -8 RMR Top feed fuel rail(Black) 14mm(No bungs) - $140
Stock JDM Throttle Body - $80
NEW- Drift Motion heat shielding gaskets for intake manifold both upper and lower - $65
Clutch Masters FX850 for an R154 with hydraulic TOB and shims(Around 2000 miles on it) - $1500
ACT 6 puck clutch with Evolution flywheel(Unknown miles) - $280
R154 transmission with 2jz bellhousing(Around 88k miles and comes with 1gal redline MT90, has new output shaft seal, doesn't grind, no VSS, has shifter extension and MK3 shift knob) $1500
NEW- AEM Boost control solenoid kit - $70
TT Igniter - $100
Coil pack with brackets & bolts - $150
NEW- AZ Performance EGR block off plate(for the head only) - $10
Cam Position Sensor - $40
TT non 6 speed Serpentine belt tensioner - $40
NEW- Standard length exhaust studs no nuts (Ordered them and they were too long for the Drewgo manifold) - $10
Upper water neck w/ 2 sensors - $55
NEW- Lower timing belt cover - SOLD
NEW- short exhaust manifold studs w/nuts - SOLD
Upper timing cover - SOLD
Metal back plate behind cam gears - SOLD
JDM 2jz-GTE head, Competition port and polish by Chris @ Porting Solutions, Also had him check the check all the buckets for proper shimming for JDM cams, has new valve seals(no sensors included) - SOLD
NEW- Induction Performance Billit timing belt tensioner w/ brand new pulley - SOLD
NEW- Gates Racing timing belt - SOLD
NEW- AEM Trim pot switch - SOLD
NEW- TRD Thermostat - SOLD
NEW- Walbro 485 Fuel pump kit - SOLD
NEW- OCD works -10 AN oil drain extender(The long 2-3 inch one) - SOLD
NEW- FSR Turbo oil feed and drain - SOLD
Stock lower JDM Intake manifold(Powdercoated wrinkle black with injector bungs welded) - SOLD
Stock upper JDM Intake manifold(Powdercoated wrinkle black with new IACV assembly, filter and no sensors) - SOLD
2jz-gte Valve covers (come with new gaskets, new connector tubes, -10AN fittings welded in and powdercoated wrinkle black) - SOLD
NEW- D3 Performance Engineering Cam position sensor block off plate - SOLD
Drewgo Manifold w/ 44mm Vband wastegate flange ceramic coated black - SOLD
NEW- ARP flywheel bolts - SOLD
To all those who messaged me, i'll be getting in contact shortly, I work night shift so was asleep.
I'll take the valve covers. PMing you now.
Andy
Due to multiple requests on the same items, all items will be first come first serve to the person who purchases the item first. I will try my best to keep up with messaging everyone back in a timely manner. The car has stared deconstruction but a storm blew in shortly after. Im trying my best to make everything available as quick as I can
Somebody's Watching Me!
Does this include interior parts? Interested in some dash parts let me know thanks
Discussion Starter #9
The car being parted out is a s14 240sx.
Also a quick update, most of the requested parts will be getting pulled off the car tomorrow & Sunday and sent out Monday afternoon before work, thanks for your patience!
Discussion Starter #11
Updated pictures & added a few things. Parts are still being pulled.
PM sent
I'll take CLUSTER TRIM, LEFT (Part # 55404-14530) if it's 100% unmodified & not damaged in any way.
Discussion Starter #19
Discussion Starter #20
Whats missing from the 2JZGTE head for a proper build? also is it VVTI?
The head is complete minus the cams, and its non VVTi
1 - 20 of 43 Posts
