1 - 16 of 16 Posts
1/2 Na-T Project
Whats up guys, I am parting out my 1987 Supra. It is black with tan interior, originally 7MGE then I did the 1/2 Na-T conversion. I ended up cracking a piston and started purchasing parts for the rebuild. I am currently rebuilding the motor with the following parts and all the machine work listed.
UPDATE: I AM SELLING ALL PARTS FROM MY REBUILD...
Parts for Rebuild:
Fully Balanced and turned Crankshaft: 165.00
.040 Wiseco Pistons/Rings: SOLD
King Main Bearings: 45.00
King Rod Bearings: 40.00
Thrust Washers: 10.00
Cometic 2.0 mm MHG: 100.00 SOLD
Full Gasket Kit: 80.00 SOLD
Bored/Honed .040 over Block(ready to go):300.00
Complete Decked Head: 300.00 SOLD
Used ARP Head Bolts: 50.00
Here is a list of other parts I have
I will get pictures up upon request:
TRD Catch Can: 30.00 SOLD
Ct-26 (Minimal Shaft Play): 100.00 SOLD
Braided SS Oil Feed and Return for Ct-26(routed to -10an bung on oil pan): 75.00 SOLD
Turbo Exhaust Manifold: 50.00
Blitz Nur Spec Exhuast: 450.00 (shipped) SOLD
MR Downpipe: 50.00 SOLD
Stock IC: 60.00
Upper Custom IC Pipes with couplers,Monza BOV(Will fit turbo with a little work): 175.00
Turbo Injectors: 50.00
New Walbro Fuel Pump: 80.00 SOLD
SAFC II: 175.00 SOLD
Innovate LM-1 w/ rpm converter and inductive clamp: 350.00 SOLD
HKS Twin Power Ignition Amplifier for NA: 200.00
Front Cusco Strut Bar: 100.00 SOLD
Rear Cusco Strut Bar: 100.00 SOLD
Polished Valve Covers: 50.00
Dual Gauge Pillar Pod w/ AutoMeter Boost and A/F Gauges: 70.00 SOLD
2.5inch Testpipe: 30.00 (Shipped)
Alternator: 40.00
Starter: 40.00
Water Pump: 30.00
Hex Bolts for Valve Covers: 10.00
Oil Pan with -10an bung welded for Oil Return(Perfect for 1/2 Na-T guys): 50.00
****These prices do not include shipping unless noted otherwise
These are just the bigger items I have...let me know what you want and I will get back to you. Thanks.
BEFORE YOU ASK FOR PICS GO HERE:
http://smg.photobucket.com/albums/v514/JTrue/ and scroll through the pages. More then likely there will be a pic for most of the items I am selling. Thanks.
1/2 Na-T Project
Discussion Starter #3 (Edited)
Bump....everything is OBO...Make some offers.
1/2 Na-T Project
Bump....
The upper IC pipes.... does it run from the fender pipe to the TB, or from the IC outlet to TB?
Steel or aluminum?
I couldnt find a pic, could you point me to one?
1/2 Na-T Project
Discussion Starter #8
Bump...Make offers before everything is up on Ebay.
1/2 Na-T Project
Discussion Starter #10
improved said:
Out of curiosity when will the pump be sent out.
You paid via Paypal with an Echeck, I will wait for this to clear and then I will send it out. Later.
1/2 Na-T Project
Discussion Starter #11
Bump...Added Some more parts
1/2 Na-T Project
Discussion Starter #12
Bump...
Parts for Rebuild:
Is this still avaliable and what would be the shipping to 76210
1/2 Na-T Project
Discussion Starter #15
Sorry, everything is gone, I sold the chasis and all remaining parts....
Ah that sucks. So I guess the Upper IC pipe is gone, along with the valve covers huh?
1 - 16 of 16 Posts
