1 - 3 of 3 Posts
Garage Queen Club
~1500 miles on them, only run through pump gas. Excellent condition, removed and stored with WD40 with caps.
These are top feed, 14mm top/bottom o-ring (domestic):
Flow Rate - CC's:
1200 CC's / MIN @ 55 PSI
1090 CC's / MIN @ 43.5 PSI
Flow Rate - LB's:
114 LBS / HR @ 55 PSI
104 LBS / HR @ 43.5 PSI
Resistance:
2.5 Ohms @ 68 F
Voltage:
8-15 Volts, nominal 13.5 Volts
Amperage:
Peak 4.0 Amps / Hold 1.5 Amps
Pressure:
Min 30 PSIG / Max 100 PSIG
$98/ea new, I'll let them go for $460 shipped in US only.
Can i use this injector with FIC fuel rail
Thank
Garage Queen Club
You would need to call them up and ask if the rail you purchased can support top feed domestic 14mm injectors (usually what most Supra guys use anyway). Chances are it does...
1 - 3 of 3 Posts
