1 - 3 of 3 Posts
Madd Tyte JDM yo ®
i have a 91 jza70 that im using for a 1jz swap. i dont think ill be using the RHD stuffs.
youll be getting just about EVERYthing you need to convert you LHD car to RHD. the only thing that i DONT have is the center console trim for the radio/hvac/shifter. the guage cluster will come with a 7M tach, not the 1jz tach. I need the 1jz tach for my swap.
parts included, but not limited to;
dash board
glove box assy
throttle pedal assy
brake pedal assy (reuse your LHD brake pedal arm)
Brake master cyl and booster
gauge cluster
gauge cluster shroud
AC blower motor unit and condenser
Heater core
RHD firewall with all bolt holes and mounting locations
front crossmember
PPS steering rack
steering column
turn signal and wiper control assy (reversed from LHD)
foglight/coin holder trim panel w/ dimmer switch
lower trim panel w/ nut warmer and hood latch lever
dash wiring and whatnot
asking $300
thanks
chris
Hardtopper
did you send my stuff yet beeeeatch.. its been over a week
Madd Tyte JDM yo ®
sorry kirky... i lost track of time working on brad's toilet. when brad comes out tomm, ill send it back with him so he can give it to you when he sees you... and the $5 too. i sent you a pm too...
1 - 3 of 3 Posts
