1 - 2 of 2 Posts
Price: $200 (not negotiable)
Contact: Private Message me here
For sale is a perfectly working Southbend Feramic sprung 6-puck clutch disc with pressure plate + throwout bearing + new pilot bearing + wavy washer for R154 Transmissions + clutch centering tool (not pictured). (This Feramic clutch setup was rated for more than 600 wtq when I bought it. The engagement is buttery smooth)
I used this with a 1JZ-GTE bell housing on a 2JZ engine and it works perfect. Or use it on the Toyota Soarer 5 speed transmissions (same).
Although the clutch has 1/2 the life remaining, you can send this to Southbend and they will rebuild everything for only about ~$200! Brand new these clutch kits were more than $800.
253175
253177
Discussion Starter · #2 ·
This great Feramic clutch is still for sale. With 1/2 the life remaining, you can use it as is too. It always held power and had buttery smooth engagement.
(The box in the picture is for a lower tq rated SouthBend clutch, but this clutch is the higher tq/power Feramic series.)
1 - 2 of 2 Posts
