Well there was a thread a little while ago that someone posted about the FT-HS being the new "Supra" Obviously it got locked, but before that I saw Larry @ SP post something interesting.
Doesn't seem like a bad thing at all this way. The only thing I am wondering is if they do this will the car go into limp mode after you reach that predetermined power level or will it just disable the motors until the car goes back to normal operating power levels?
I assume this will only be a problem if the electric motors contribute a significant amount overall. It sure would make for some tuning problems I imagine as well though. Also from a handling standpoint, if the motors drive the front wheels and the engine drives the rears, then the car could change it's dynamic completely halfway through a turn after laying down full throttle.
Alex
Think of it this way: Say you turbo the car, or what have you, and you added 200hp. Well while driving around town the electric motor should function as normal. With light loads it should also function as normal. Once you hit good boost or turn up the wick a little then you lose the electric motors.I have spoken to a few of the head powertrain engineers at Toyota.... Basically you cannot modify this car at all!! The hybrid ECUs have a predetermined amount of torque that they will let the wheels see..... therefore if you increase the output of the gas engine, the ECU will decrease the amount of TQ applied by the electric motors!!
Alex
