ok so yesterday im driving like normal and the car dies and wont start so we get it home and check for fire....fires good so we check the air filter looks good then we pulled the return line from the fuel rail and it pumped fuel through but this time it fired up......so we put the line back on and it wouldnt start....took it back off and this time it didnt start again im throwing no codes and the car is still in my shop any suggestions?
ok we got the car started and it threw a code 12 im not sure what code 12 means it has to do with the cam and crank position sensors but what could it be that is wrong all of the sudden?
1JZ BLING!
crank sensor
the wiring going to it is probably flaky.
The crank sensor is at the bottom of the engine, passenger side, under the alternator. Look for the 2 wire connector.
