1989 7mgte swapped mk3
I tried searching and it wouldn't work...but how hard is fuel filter on an n/a to change? Any special tricks i'd need to know. Is it located just above the diff. I think that's where I saw it? thanks...
I'm not sure on an NA, but on a turbo its a bitch unless the tank is dropped. I just did mine a few weeks back because I installed a Walpro. I can't see it being different.
Mo
RIP 86.5 N/A, Hello 90T
I've done it on several NA's and Turbo's they're both the same. A PITA trick is have skinny bendable arms. I mean like stretch armstrong elastic arms.
Yes its above the diff
slowly giving up...
drop the tank. it's worth the trouble for the extra space you gain. use flare wrenches, and PB blast. i did mine in about 20 minutes. (after the tank was dropped, which took 20 minutes)
the key is to soak all the nuts/fittings/etc.. in PB blast before you work, and they'll come right off. ;)
-shaeff
